This is more of a general advice post really but ive posted here as it is building related
Im hoping I can get a bit of advice/guidance from some of the experienced trade people on here.
I recently moved into the first floor of a 3 flat converted Victorian house. Not long after moving in I found out from the owner of the ground floor that the entire rear wall and part of the side of the house required repointing. This was carried out around 18 months before I moved in.
At ground level the rear wall of the house has an existing extension which is an addition of the ground floor owner. On my level and on the second floor are some upvc double doors which open inwards.
A few weeks after moving in and during some heavy rain I noticed the upvc doors had let in some water.
On closer inspection it became clear the doors appear to have dropped significantly and do not close properly. In addition the rain deflector bar was missing from the edge of one of the doors.
The amount of rain that came in was not significant….just enough to get through the carpet but not through the underlay and floorboards beneath.
I have since installed a rain deflector and applied some silicone and have had no further issues with water ingress.
Just to be sure and out of courtesy I checked with the downstairs owner to make sure there was no water ingress to her property. Her answer was no and that there was no issue there prior to me moving in.
A few weeks have gone by and ive now got the downstairs owner complaining about hairline cracks showing in the lintel above the entrance to her extension. (This is directly below where my doors are) No water ingress or any signs of it, just a few hairline cracks.
Her ‘builder’ friend has been on the roof of her extension that to inspect my doors.
This guy has advised her that the doors could be the source problem and they are in need of repair.
(On a side note I also found out that this guy is not actually a builder but a developer who get his lads to do the actual building jobs….. Turns out that he build the extension and did the repointing work. Whether asked if they removed and replaced the answer was no)
I have had a few guys out to inspect the doors and quote for repair or replacements both have said it looks like the doors were removed at some point and refitted badly. The general verdict is the doors are old and need replacing which is fair enough
That’s about all the background info I have on this
The main question I have is do any of you think the doors could be the cause of this issue?
Admittedly the doors do need to be looked at as they do not close correctly however I’m not so sure they could be aren’t the cause for the cracks appearing in the property below. Furthermore there has been no water ingress whatsoever since I took the steps of installing the rain deflector and sealant. In addition this the cracks don’t appear to be propagating or widening significantly.
What concerns me more is what has caused the movement in the doors in the first place
Since I am able to shut and lock the doors with no issues so I have put this task near the bottom of my list until I have the budget to get it fixed however I now have this woman on my case telling me I need to get something done or get the doors fixed!
I plan to get a qualified builder out to look at this but in the meantime do you guys have any advice on the best way to approach this one?
