Postcrete or Cement?
Status
Not open for further replies.
24 Apr 2004
The reason i ask is that i need to put 19 posts in, and postcrete is £3.62 a bag with a total of £68.78. Now i now Cement is cheaper than thia but don't know how much to order or what sand would be the best.
Any one can offer any advice.
Hightowermark said:
Now i now Cement is cheaper than.....
Yes but you need to mix it with ballast to make concrete ;)
Ballast will probably cost £22-£28 per cu m. Plus a hlaf dozen or so bags of cement at say £2.50ea, plus rapid setting agent.
Ordinary mortar mix will not be strong or heavy enough for fixing posts.
Postcrete is basicaly rapid setting concrete.
the blue circle postcrete in wickes is only a couple of quid a bag, and usually enough for two holes. I have to say of all the ones i have used it is by far the best and cheapest, sets quickly and goes rock hard.
Yea, gotta say, I used Postcrete for the first time the other day to over-engineer a post in the ground for a rotary airer. Didn't want to use it on anything more than that first time round.
That stuff is great - really good. So worth the little bit extra you'll pay. No mixing, left over sand, no mess.
Dig your hole.
Put the post in.
Drop the bag on the side of the hole.
Cut a slit along the bottom of the bag.
Pour water.
Make Tea.
I used post crete and found that i needed at least one bag per hole because my holes were quite large after excavating many mang boulders from beneath the ground.
I therefore favoured mixing my own concrete, made with rapid setting cement, which seemed to work much better for me.
thatswhy i use a one man petrol post auger, nice neat small hole, exactly where i want it, nice and quick, no faffing about with supporting the posts in an oversize hole.....oh and a bag or two of postcrete is ample for the hole! :D
___________________________
moderator
post locked to prevent hi jacking
Status
