It aint making the right noises if you cant hear the burner fire
If you are indeed a ham fisted amateur and not a competent engineer or even anything like; it would not be wise for us to suggest you go changing ignition PCB's and stuff
Thanks guys- was thinking it was the thermocouple as I have had trouble in the past getting the pilot to light- will get an engineer to look at it just wanted a little knowledge just so I didn't end up with a cowboy as the misses would be likely to be at home, and she has a habit of just saying yes to anything- (well anything that involves spending money).
