Just before Xmas 2004 my boiler packed-up. The maintenance contractors replaced the Air Pressure Switch, Printed Circuit Board and finally the Fan (over a 30 day period!)before it worked again. Since that time the boiler ignition is worryingly loud (like a small explosion) it will then run for a couple of minutes and then shutdown without reaching the required thermostat setting. After another couple of minutes the whole ignition sequence starts again, and again, and again until hours later the system reaches temperature. Can anyone advise me if there is a simple answer or should I call out the maintenance contractors yet again? (you must get the impression that I do not trust them!) Thanks for any help and guidance.
