I had a new FSB30E installed in April 2008 and in 3 months the condensate pump and electronics module were replaced. Catastrophic failure after 8 months later - heat exchanger cracked / leaked water - replaced together with burner, fan unit and electrodes. Now 18 months later same problem - heat exchanger cracked and leaked water - luckily covered under extended warranty. Heateam engineer cannot see problem with installtion (straight replacement for an older boiler/system that was open vented gravity water and pumped heating - but now fully pumped and open vented). He thinks it is soft water and therfore will fill with hard water + add inhibitor. Will this fix the problem? has anyone had similar unfortuate experiences with this product - could be a design defect?
Cheers
Cheers
