potterton envoy system 40 trouble
17 Apr 2004
This boiler is giving me several fault codes e.g 1,2,3,4 I know what the codes mean
Is it the pcb ,
The boiler will run with the fault code displayed!!!!
Since you don't identify one specific code and '1 ,2, 3, 4' are completely unrelated to each other, it sounds like the display and / or the display driver in the PCB is stuffed.
Have a look yourself at http://www.partsarena.com/baxi/ and see if you can relate the code(s) to the descriptions you'll find there.
Sensor
Flow or return sensor out of calibration
See chart
2
Flow sensor
Flow sensor is incorrectly fitted
Check sensor
3
Case temperature
Temperature within boiler casing too high
See chart
4
Dry fire
Boiler has been fired without water
Check system
u beat me too it....
envoys are pants
the condensate trap is always blocking and flooding the bleeding things, I always rip them out when I get one as you'll end rebuild it and STILL have loads of call backs
