I have a Potterton Kingfisher RSL100 boiler on a sealed system. Over the last couple of days I am getting lock-out errors.
When I reset the system, it can then run again fully through the cycle without issue. At this time of year, I am only using the system for heating water. Around 80% of the time, this is fine.
I understand the lock-out errors can occur if there is a blockage in system, the pump is not working or the thermostat has failed. Since the system heats water most of the time, am i right in being able to dismiss both a pump and blockage issue?
One last thing, on my road the gas main is being replaced. Could there be rubbish in the pipe clogging up the jets?
Any help would be gratefully received,
thanks.
thanks.
