I did use thermal transfer paste and the pump is set to 2. The system runs using pumps rather than motor valves and at time of overheat, both the flow and return pipes are redhot.
the presure gage on the pressure vessel is set to 1 1/2 which I was told was about right?
Unfortunately, it could be the PCB although in my experience thats less likley for this type of problem.
It could also be a gas valve problem, settings or faulty.
Since the PCB is quite expensive I would always eliminate all the other possibilities.
A simple one is to test the potentiometer but that does have to be done properly!
You may need to call out a registered engineer but with this kind of more difficult fault it will have to be a good one! Make sure its on a no fix-no fee basis!
