We have an ancient old Potterton Netaheat boiler which has served us well. I've just switched it back on after Summer to make sure it's good to go when needed, only to find there's a problem.
The problem is that irrespective of the controller (Siemens RWB9) being set to off for both HW & CH and the central room thermostat being set to off, the pump hums away and fires the boiler up every 10 mins or so, runs for 5 mins then switches itself off.
If the controller is set to on, everything seems to be working fine.
From what I've gleaned from this forum and others, it could be the PCB. I've had a look and the capacitors (usual suspects) look ok and the soldering looks sound. I'm also wondering whether the controller is teh culprit as it does do some odd things like when the CH is advanced for 1 hour, the HW light comes an as well. I've reset it to no avail.
So any thoughts/advice most gratefully received,
Cheers,
Pete
Cheers,
Pete
