Potterton Netaheat Mk2 10/16 - PCB availability ?
13 Nov 2005
Buckinghamshire
Hi all,
I've got a sick Potterton Netaheat Mk2 10/16, which has been diagnosed with a faulty PCB. An engineer I had out popped along to his local supplier and picked up a replacement PCB, only to find it was the wrong type. Another trip resulted in yet another wrong PCB. A phone call to Baxi confirmed that the PCB was obsolete. This is, I accept a very old boiler.
Anyone confirm this? Is there a parts source for obsolete PCBs for this boiler?
Searching the net I've found part #s 407676 & 407677 - neither of which look like my PCB.
What are the symptoms with regards to the boilers operation (if any)?
Boiler stopped working Friday evening. I noticed the 1amp fuse on the front had blown. I replaced this and this got the boiler working again. However, 2 hrs later, the boiler stopped working, and the fuse has NOT blown.
Turning the dial no longer shows any spark inside. There' a click, but nothing else. No fan noise (that I can hear), no gas noise, anything. Just nothing.
doh .. I've been looking at the wrong thing. I was looking at the spark generator, not the PCB.
Aftermarket (reconditioned) PCB's seem to a plenty for this boiler. Code seems to be POTTERTON NETAHEAT 10/16 PCB 205295.
Is there any reason (other than the obvious, "we'd like to install a new boiler in your home sir", as to why I shouldn't look at the replacement (reconditioned) PCB route ?
I would be suspecting the fan as you can't hear it, of course if there is no power to it then you wouldn't but IIRC the fuse protects the PCB from a faulty fan.
