Potterton Performa 24 advice
14 Sep 2010
Hertfordshire
My shower keeps running cold patches but the other taps in the house are fine.
I had this problem 4 years ago and the guy replaced the 'plate heat exchanger' and said 'system needs flushing to prevent problem re-occurring', what does this mean and is it too late to fix it? I got charged £188 (labour/part+VAT) last time but am a bit skint at the moment to go through this again. Why has it happened again?
Matt
This has happened because your central heating system is full of crap-hence adviseing you to get system flushed.
Replacing/cleaning the plate heat x is half the job,the water ways through the plate h x are very narrow so the crap collect until it impears you hot water quality.
Why did the plumber not flush the system? How often should the system be flushed? Would flushing the system now help?
Most of the crap comes from the original system to which a combi is then fitted,This should have been done whenboiler was fitted, but quite often doesnt get done !
As to why he didnt i dont know he informed u? U need to sort that with him
Usually once clean it should just need inhibitor checking and topping up every year or two!
so why didn't you get it done
because you didn't ask him to :idea:
depends on the layout
stable door and horse away springs to mind :shock:
