- Joined
- 16 Feb 2018
- Messages
- 2
- Reaction score
- 0
- Country
Hi All
Thanks in advance for any help - I have a Potterton Performa 24 which is playing up. The boiler is not striking automatically when either a hot tap is turned on, or the thermostat calls for heat. However, once there is a call for heat from either circuit and the boiler is turned off and on again it will fire up and run reliably.
My wife tells me going to the boiler cupboard to power cycle it every time you run a hot tap or want warm radiators isn't a long term solution....
Any suggestions?
Pressure in system is fine, DHW pressure differential valve appears to operate correctly.
M.
M.
