Hi guys,my hot water takes a while to get hot from the tap,could it be the diaphragm and is it a big job to replace,ie drain all system or can you just drain the boiler on its own?,many thanks for your time guys
The diaphragm is one cause of poor hot water, but not the only cause,
far more info would be need to make a diagnosis - rather than randomly guestermating the fault and changing parts that may or may not need replacing it would be far better and probably cheaper to get a boiler service engineer in to have a look and fix it for you!!
