I've been having a problem my Potterton Performa 30 he boiler. I've just bought the house and the boiler is as installed, on first attempt to fire up the boiler, I found that the 2 Amp quick blow fuse on the PCB had gone, on replacing this, the boiler worked fine for two days until the PCB fuse went again!. So I replaced the fuse for the second time yesterday. Today on attempting to manually turn the heating on, vie the on switch on the programmable timer, there was a flash and the timer went pop! Again the fuse on the PCB -fused. Any thoughts on what may be causing this? If the timer went pop/flash does this indicate that the timer is at fault and needs replacing? or is incorrectly wired? note this did work ok for a short while. or is it likely something else?
Any help greatfully received, its pretty cold here!
