Tried searching the forum but nothing matches my problem..... So here goes, I have a Potterton profile 60E that was not firing up - called in Plumber who said it was PC Board - fitted new one but still no good - he then turned the Boiler Thermostat to the "0" posistion (it was on 3) and the system fired up. Unfortunately it died 10 mins after he had gone. I then contacted a heating engineer who lives near to me to have a look he said it could be the system need a power flush or even a new pump as he had one in his van he said he would change it to see if that was the problem - he did and the boiler fired up again this time long enough to heat all the radiators.
The real problem arises when I have had a shower if the heating is on but has the thermostat set low as not to call for heat (set it 10c on room thermostat) the boiler fires up on it's own and the only way to stop it is to turn it off completely. Also if I have to heat the house for a long period the boiler cuts out make a real racket and I can hear water gurggling in the loft - cold tank is always full to the top and the expansion tank is a 1/3 full (with steam coming from it) so i have to have the heating set to constant and move up in increments of a degree or 2. This also happens exactly the same if I have a shower and the heating is on - so i have to turn off before using it. After a while I have to press the reset button on the boiler and I will hear the sound of water flowing into the boiler and it will fire again but only for a few minutes and trip out again if I do this a few times (after a wait of 10 mins in between each reset) it finally works again. All the radiators get hot and I have bled them all in case this was an air lock.
Hope someone can help with this.
