Our new build house was fitted with a Potterton Promax 15/2 HE Plus boiler heating a thermal store for mains fed hot water and radiators with TRVs (except 4 of them) in a 'Y' plan configuration. I've never been overly happy with this setup and we've been having an ignition lockout issue with the boiler recently.
I've recently had it serviced with a new spark electrode being fitted and I've just swapped out the PCB assembly to rule out any faults in that which may be affecting the boiler failing to strike up in the allotted time before going into lockout.
The thing that I noticed is that the PCB has two jumpers on the board, labelled CN11 (Blue) & CN12 (Red). Now my question is, what do these actually do?
In the generic installation manual it suggests that they are fitted as default, but on a Promax 30 HE Plus the CN12 (Red) jumper could be removed to increase the the output from 22kW to 30.18kW. It then goes on to say that "if the boiler is used in conjunction with a Thermal Store, the boiler can be adjusted" by removing both the CN11 & CN12 jumpers.
Now for the last 7 years they have been fitted! What effect will it have by removing them? Is it going to increase the output of my smaller 15/2 boiler? The manual makes no attempt to describe what these jumpers do and note that it does say "can be adjusted", not "has to be adjusted".
I guess in my long-winded way I'm hoping a Potterton expert can tell me the theory behind the operation of this boiler with regards to the jumpers and a Thermal Store.
Many thanks for your time & help.
Regards
Sean
Regards
Sean
