why shouldn't it as the fault can be related,plus you don't know what the insurance procedure is so your comment is unfounded and wrong
and your assuming again
. fooking hindsight is fooking lovely isn't it
firebladerrw I've replace quite a few flow switches on this boiler for which the paddle is the weak point , you may have a bigger problem but you need a multimeter and know how to use it to know this problem, if you do let me know
. other than that i would be looking at the pump but then again you need a multimeter to go any further relating to this fault as it could lie elsewhere
how long does the lockout light come on when the firing sequence starts ???
by the way its a shyte boiler as its related to the promax SL![]()
Thank you, mechanical and electrical chartered engineer here, so yes I can use a meter. And I agree about the boiler!
It's goes instantly to lock out. It doesn't start the ignition sequence at all. Flow switch has been replaced as per above.
I wouldn't bother with the guy above, he's what is known as a forum troll. He adds nothing to the site except innuendo and snide comment, without any thought of who he is addressing,
. Some of us have more qualifications than a two week gas safety course, which of course is mandatory if you are actually going to work on a gas appliance, which I'm not. This whole thread is to help my engineer who may not be brilliant, but he has a gas safety certificate...
Probably responsible for people leaving here. Like many others, I tend to ignore his interjections.
