Can you name even one boiler where you can reach the fan motor without opening the combustion chamber.
Halstead Bentley ?
Halstead Bentley ?
strange thing is exactly 10 feet away from me is a halstead bentley in my house
I am sorry to say that you are wrong about the Puma and the only candidate which has been mentioned is the Halstead Bentley.
Don't you remember the Puma? Would you like to come and see one and I will even give you a coffee when you admit that you are wrong.
Of course there are trolls on forums who state that black is white just to be provocative.
transam";p="1824166 said:The combustion chamber is the combustion chamber , wether it is negative or positive is in this context irelevant !
What I was stating is , that anyone can remove the cover/door from a boiler that is NOT sealed to the casing to carry out unrelated gas work, for instance to change a pump or diverter valve etc. Do you agree ??.
Spraggo you dont know what you're talking about.
in every case the fan impeller was accessable INSIDE the CC and the fan motor and motor cooling fan was accessable on the OUTSIDE of the CC.
As you should know, being a RGI, that boilers with sealed cases were restricted to the ones that worked on positive pressure within their combustion chambers
combustion chambers of the Potterton Puma and Halstead Bentley for example, have negative pressure and therefore it is not illegal for Diyers to remove these boiler cases
Read my previous qoutes and think about it. So what you are saying is that the casing door on your Halstead Bentley cannot be removed only by a RGI
Rob";p="1825033 said:The motor is bolted to the side if the fan how can one be inside and one outside
If you remove the casing from your boiler you will note that there is a small fan on the top, known as the motor cooling fan, by spinning this fan you will also be spinning the motor and the larger fan inside the CC.
Perhaps if I had stated that the boiler casings on positive pressure boilers acted as the CC you would have understood better.
If no gas related work was carried out on your boiler what safety checks would you have to carry out after refitting the casing. Considering that I don`t know what I am talking about , please reply as I am always ready to learn.![]()
