Hello everyone.
I must apologise as my first post is to ask for help, but iam in desperate need of some assistance.
The CH stopped working about a month ago, so i recently got hold of a new PCB for it, about 2 days before i put it in the Hot water also stopped working.
There was no power to the thermostat and the pilot light kept going out.
So i fitted the PCB and a new thermocouple. The pilot light now remains lit, and i now have power to the thermostat. But still neither works
when i turn the thermostat up the pump starts to run and the fan is running too, but the boiler fails to light. when i turn on the Hot water the LED on the PCB comes on but yet the boiler fails to light.
I have checked the Hot water flow switch which is fine, i have measured the esistance across the gas valves which appear in spec, all the other switches appear to be ok, but i ain't no boiler engineer.
So i have just installed a new transformer, just guessing now, but its no different.
So everything seems fine but the boiler is just not lighting on either CH or Hot water.
Is there anything i may be missing?
Regards
Matt
Regards
Matt
