I have a combi boiler, and it seems to fire but does not heat the radiators or the water. It happened before and my husband had instructions and fixed it. It says locked out. Instructions are lost and we're cold! Any ideas?
U say it fires but has also locked out ? I assume u mean it fires THEN locks out, presumably u have pressed the reset button on the front ?
First of all look at the central heating pressure dial (underneath right hand side) should be set at 1- 1.5bar or thereabouts. Tap it a few times make sure its not stuck first and top up pressure if req'd.
Next thiing. is it the model with the Pilot, (has a grey ignition button over on the left) and can you see the pilot light (which is pretty difficult at the best of times)?
Also check the Low Pressure light, on the front isn't on, or it won't go regardless of what the pressure is.
Good shout. Tho i couldnt remember if the perm pliot one had a lock out/reset function on it, presumably if there was sum kind of overheat prob the pilot would cut off ? I forget now.
Im off to find a pic of this boiler so i refresh my memory.
It sounds as if you have a model with no low pressure light.
If thats the case you still need to repressurise to about 1.5 Bar. See the FAQ section on this site.
Most likely then to be the DHW demand switch is stuck on or sticking on after DHW demand. Thats a common fault and you can read about two examples each week on this site.
