I have a Puma 80e which has had several problems over the 10 years we been using it(New fan, DHW switch, Modulation PCB dry joints, bleed valve etc.) I might be a bit paranoid but when the CH is running and the rads are hot, the boiler seems to be continually firing up and switching off approximately a couple minutes each time or even less. I am sure it never used to do this, I think there might be a problem with the CH temperature sensor. I've searched the archives but have not found any similar problems. Hope someone can help me.
PS. this my first post
