Potterton Statesman Flowsure (again)
  • Thread starter Thread starter Igorian
  • Start date Start date
I
Igorian
Hi guys
After running a bath, I notice that the boiler overheats and the lockout illuminates. This can be reset after allowing it to cool and all then seems fine.
The problem doesn't seem to occur if using CH or just filling a basin/kitchen sink.
System pressure appears ok (ranges from 1 to 1.5 bar), pump appears to be running and it doesn't appear to need bleeding.
Can anyone offer some suggestions/tests I could try?
Is this a Flowsure or a Flowsure "+" ? the "+" Model has a mixing valve and a hot water thermostat strapped to the HW outlet above the plate HE, if it has these items check that the HW stat is working
also check that there is not air trapped in the boiler pipe work there are about 5 manual air vents in diffrent locations under the top cover of the boiler - air trapped will cause overheat :wink:
Hi, thanks for the reply.
It's just a Flowsure, not the +.
There are two manual air vents which appear to be ok (ie, passing water rather than air).
I've looked back at previous posts I made on this and it was suggested that the flow switch may be sticking. This was replaced 3 or 4 years ago, but appearently they can be problematic on this model. I'm going to check it over this w/e to see if this might be the cause.
I'll let you know what I find.
Cheers
Ian
