Can anyone help.... I have a Potterton Suprima 30 boiler, the boiler fires up normally however the central heating And hot water fail to reach the desired temperature (room stat selected high, hot water tank stat selected to 50 degrees and boiler temp selected to high).The boiler continues to run for approx 20 mins then cuts out. The 3 port valve and overheat stat have been replaced as recommended by a local plumber but the fault still remains. The pcb was replaced with the updated siemens board 6 months ago for a different fault. Do the new boards also suffer as the old boards did???? The system has been bled and the pump is running....
