Hi everyone.
I was after some advise about my boiler. I recently had a new gas valve fitted and all was well but the boiler has developed another problem.
Basically, the boiler does not shut off the gas regardless of what setting I put the dial on. (The one on the boiler). The boiler then gets too hot and I get a 'lock out' - ie red flashing light. I can let it cool down, reset it and it fires until the same problem happens again.
Could this be a faulty gas valve or is it likely that something else has gone wrong. I have seen a lot of posts on here about dodgy pcb's and was wondering if that could cause the fault im getting.
Thank you
Mike
Thank you
Mike
