    Dismiss Notice
Potterton Suprima 60L - GCNo.41-590-45
Discussion in 'Plumbing and Central Heating' started by Firbel, 3 Feb 2019.
  1. Firbel
    Firbel
    24 Feb 2008
    29
    Thanks Received:
    Leeds
    Country:
    Hi, can anyone tell me what the latest PCB Part No is for a Potterton Suprima 60L.
    Present PCB Unit is 5107117. Does 5111603 supersede this and is it a direct exchange for the 5107117 ?
  2. MeldrewsMate
    MeldrewsMate
    27 Jan 2010
    1,009
    Thanks Received:
    243
    Buckinghamshire, Darn Sarf
    Country:
    Can't help you with the part numbers, but the replacement PCB is a complete sealed assembly complete with wiring loom that replaces the whole mounting that the old PCB screwed into.
    Suprima, eh? Must be over 15 years old...
    MM
  3. Sponsored Links
  4. Firbel
    Firbel
    24 Feb 2008
    29
    Thanks Received:
    Leeds
    Country:
    Thanks for the quick response MM. Yes it's an old unit though not sure of its age as the Year Box on the label is blank.
    Am I right in thinking the original PCB was a bare unit with separate Red and Green Leds and the replacement unit only has 1 indicator which displays red,green or orange depending on the status. The later sealed (boxed) unit is available as 5107117 (currently fitted) or 5111603. I'm trying to determine which is the later PCB.
    Read more: https://www.diynot.com/diy/threads/potterton-suprima-60l-gcno-41-590-45.517638/#ixzz5eVUq0qUg
  5. MeldrewsMate
    MeldrewsMate
    27 Jan 2010
    1,009
    Thanks Received:
    243
    Country:
    You are correct in the description, but I cannot help you regarding part numbers. Suggest you ring Potterton for clarity on that subject.
    • Thanks Thanks x 1
  6. Sponsored Links
  7. Firbel
    Firbel
    24 Feb 2008
    29
    Thanks Received:
    Leeds
    Country:
    For the benefit of others the replacement PCB kit for a Potterton Suprima 60L (GC No. 41-590-45) is 5111603
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
