potterton suprima air lock
24 Apr 2007
Please pls can anyone help i drained my system 4 days ago because putting in new towel style rad in bathroom and had to move pipes this was ok.
when i was done put a de sludge in and filled it back up bleed all rads no problem bleed air out near hot water tank again ok
Then started up system and my boiler went mental 8/10 big bangs/knocks and shut down can anyone pls tell me if i can bleed the air out on my suprima boiler anywhere else as im stuck as to what to do
THANKYOU stuart
Big bangs knocks will be lack of circulation. Check pump as corgiman says or check for air locks.
yes i have checked pump is running its new and thats my problem a AIRLOCK should i run the pump slowly and just keep bleeding it when it shuts down?
stusay said:
yes and your point is what pls do tell
Right I am done with helping
as rob says get someone who knows their arrse from the elbow to sort it for u
I was just asking the question and then I could have moved along a bit
but there u go, sure one of the others will help a rude boy like yourself
