I'm a recently qualified domestic acs engineer (started as a plumber, still quite young and lacking tonnes of experience) and work for a company in london servicing boilers etc.
just finished a private job on a potterton suprima 30 wall hung boiler. the job was to change the pcb. its a Y-plan set up.
I started by following the potterton literature and firstly removed the 2 purple wires for the fan motor then the two yellows for the thermister then the two white wires for the high limit stat. everything went ok except for two things:
1. the thermister was very loose fitting back on to its socket on the flow pipe (almost as if it were hanging in) which is a bit of a concern. should that not be a nice tight secure fit?
2. the melox (or velox- can't remember the name) connector block for the gas valve came without a bridge for either side of the earth. had to take it from the old pcb, which eventually helped the igniton electrode to light the gas. I take it this lead is essential for what I'm assuming, is a flame rectification device?
any responses would be welcome. its quite daunting at times when you're a bit new in this game and you have a customer askinglots of questions while you're a bit stumped with a boiler problem
