First time post - go easy on me.
I'm building a side-return extension on my victorian terrace which also requires the removal of two internal walls which divide the kitchen into 3 rooms.
To keep the house functional and to save money, my plan is to work my way back from the end of the house (the actual kitchen is in the first third currently).
I need to dig out the entire floor and start it from scratch, so was planning to set the slab in stages, to minimise the disruption.
I have the end of the house dug down and ready to go (once I've put down the hardcore, blinding sand and DPM).
My question is, can I create a form to prevent the concrete from reaching the wall which I'll be removing, but set in it some steel rods which will protrude from it horizontally, then when I've removed the wall, do the same again for the 2nd third, but allow that pad to set up to the first and as a result envelop the steel rods? Does that make sense?
I'll try and explain a different way. Can I lay the pad for the whole room in stages, if I connect them in some way? If so, how would I do that?
Thanks.
Thanks.
