Power Shower with Worcester Combi boiler
28 Mar 2008
Bath
I am installing a shower room upstairs. I already have a downstairs bathroom with a thermostatic shower, running off a Worcester 28 Combi boiler.
I am fitting an electric shower upstairs, but I also have a multihead shower unit which I would like to put opposite.
The large unit could run off the combi boiler, but I have asked whether I could increase the pressure using a separate pump and have been told by a plumbing expert that this is possible. What pump should I use. I will install this under the floor boards. Should this be a dual (hot and cold) feed pump.
Does anyone know the make and model number of a suitable pump?
even if you could...(but you cant) the combi would not heat the water up enough
