Run two electric showers off a combi boiler ?
20 Sep 2005
Hello.
I have had a chat with a plumber who suspects that it will not be possible to run, concurrently, an electric shower downstairs and another electric shower upstairs because they both run off the mains pressure which will not be enough for two showers.
The boiler is a Worcester Bosch combi and the mains pipe into the house is 15mm.
Surely it must be possible to get two electric showers running off the mains ? :confused:
Thanks in advance.
Shouldn't be a problem since the flow to the two electric showers won't exceed 8 litres/minute. However you need to check that your electricity supply can handle the load. Also get yourself a decent plumber.
Electric showers don't run off the combi, they heat their water independently. But why don't you run one normal shower off the combi? It will give better flow rate and be cheaper to run.
Someone else mentioned this and I wouldn't say no, but I asked a plumber and he said you can't run a pump off the mains supply. Is this a fib ? :confused:
Hmmm, me thinks I am not dealing with a plumber who knows what he oughta :rolleyes: I'll get some more advice...
Ok, so, in the opinion of you learned people, the following setup should work okay ?
Worcester Bosch combi fed by a 15mm mains supply
Electric shower in upstairs bathroom
Mixer shower in downstairs bathroom
Yes :D
Put the mixer in the bathroom you shower in. You won't ever use the electric one after showering off the combi. ;)
how to get wet in an electric shower
:LOL: :LOL: :LOL: :LOL: :LOL:
Bahco said:
Yes :D
Sounds good :D What about having mixers upstairs and downstairs ? or would that "overload" the Worcester Bosch combi and end up with two dribbly showers ?
Ok - thanks. One more question I'm afraid :LOL:
If our washing machine is only hooked up to bring in cold (beacuse it heats the water itself), how badly would this affect the mixer shower ?
Thanks for all of your help and advice. :)
kevplumb said:
depends on the mains pressure and flowrate
...and a decent plumber will be able to verify these for me fairly quickly ?
Are there any figures that are ballpark as "good" ? Also, what should the figures be measured in, PSI or litres per minute or something else ?
