Hi folks!!
I recently had a very old prefab garage knocked down and replaced with a more modern and larger prefab.
The previous garage had power supplied from the house CSU on a ring main 2 sockets and a couple of flourescent lights. Obviously I disconnected all this long ago as there was no CSU in the garage and the roof leaked all over the sockets in there.
Anyway I now want to run power back to the garage and although the previous supply was off the CSU it's not that easy be re-connected as it means taking up a LOT of laminate floor upstairs. Really I should have thought about this before laminating but hey ho!!
The garage is detached but less than a meter from the house. Can I take a spur from the back of a kitchen supply into a RCD protected CSU and then run a double socket (that's all I need in terms of plug in power) and then say 4 flourescent tubes from the respective supply out of the consumer for this ok?
What about the cable from house to garage. Seems crazy to have to bury 700mm deep or whatever to cover about a 800mm span? Or can I run conduit it the house wall and then across to the garage?
Oh the load in the garage from powerpoint will not be huge although I may use welder from time to time. On saying that I did all my wleding previously by plugging into a kitchen socket and an extension!
Thanks in advance ...
