JohnD said:You can get a Mole device that tunnels through the ground towing the cable behind it.
An easy job but the contractors prices are set to be about the same as digging up and reinstating the road, since that's what people are willing to pay.
You can have a look at the land registry documents to make sure you really do own the land and see what rights are registered against it.
breezer said:gas board use them too.
but you still ahve to dig 2 holes, one at each end so i believe
JohnD said:I would be inclined to put a duct, at least under the right of way, to avoid ever having to dig it up again.
While you're at it, lay one for the phone cable.
And the TV
And the Broadband
And the alarm
And the water pipe.
And the draught lager.
breezer said:must be good operators then, because i borrowed the above pic from the site mentioned.
hole at each end
breezer said:yes, but it wouldnt know which way to go
