Hi All,
I realise this question has probably been asked a thousand times however.
I want to run some power to my garage, i realise that it will need to be armoured cable, burried at a quite a depth.
I will have a small CU in the garage, covering what will be a couple of sockets (trickle motorbike charger, occasional vaccum), a strip light, and an LED security light - so not much power draw.
I have 2 questions,
What size breakers would i need in the CU?
Also, by far the easiest option in terms of not causing issues to the decoration of the house, would be to wire this in in the outside box, after the electric meter, i believe there is an isolation switch/fuse in there, so that shouldn't be an issue. - is this acceptable?
THanks
I have 2 questions,
THanks
