- Joined
- 27 Jan 2008
- Messages
- 29,587
- Reaction score
- 3,645
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I know the insulation on a fridge/freezer can fail. When this happens because it is cold it absorbs moisture from atmosphere which in turn conducts heat into the unit.
To check on this one should from time to time measure how much power over a given period it uses.
However door opening, setting, ambient temperature will all effect reading so until this time next year I will have no figures to compare with.
I have just run for 24hours with measuring machine connected and it used 2.1KWh but no idea if that is high or low? I will assume form calculation it was running 18% of the time.
Has anyone go any figures I can compare with?
