Trying to do it right
Our house is on the market & we are making plans for the move. (Isle of Man to Scotland) We have a number of tropical fish tanks, 2 large tanks, 3 medium sized & 20 small tanks. Each tank has a filter system. Each filter holds the biological media which allows nitrification bacteria to live & complete the nitrification cycle in each tank. A nitrification cycle takes about 6 weeks to create in a tank with no fish, or 6 months to create in a tank with fish. A filter unit also includes some filtration media & the water is pumped from the tank through the filter & back into the tank with a small impeller.
During the house move, which will take 2-3 days, we will put the fish into separate buckets with heat packs. The aquarium tanks will be empty for tranportation. We must also maintain the bacteria within the filters. To do this, the bacteria needs constant warm oxygenated water & food. If no fish are present, this can be a controlled dose of Ammonia.
Although the fish prefer a temperature of 28-30C, we will run everything at 24C to improve oxygenation.
I have roughly calculated the wattage of the filters & this totals 163W. Multiply this by 3 for safety & this gives 489W.
From previous experience, I have found that impellers need to be powered by a pure sine-wave supply. In case of power cuts at home we have a stepped sine wave generator powering a stepped sine wave 1.5kVA UPS (for the heaters) & two pure sine wave 750VA UPS units.
To do the trip, we hope to hire a large van. The filters will sit alongside food safe buckets with heat packs & will be seeded with Ammonia. We need to power the filters.
Running a generator in the van doesn't sound feasible & also would not be allowed on the 4 hour ferry trip. The UPS units will not run the filters for 2 days. My thoughts are to get a pure sine wave inverter, possibly 1000W. Also to get a camper van type 12V battery of say 110Ah.
My calculations seem to suggest that my power requirement is just under 1A (seems a little low to me). If that is correct, then I think that I have 110 hours of running.
Filters as follows:
4x 17W filters
3x 5W filters
20x 4W filters
Some questions:
Is all that rubbish?
Are my calculations correct?
I would locate the inverter & battery higher & well away from all the water buckets. But is there some chemical risk from the battery & inverter that I am not aware of?
Is there a better way?
Thank you.
Filters as follows:
4x 17W filters
3x 5W filters
20x 4W filters
Some questions:
Thank you.
