powermaster-10 GSM SMS reporting
13 Jul 2014
I'm trying to get my PM10 to basically send out Voice and/or SMS report to private numbers.
In other posts here I understand it can contact mobiles directly. Is this possible or am I missing the point, i.e does the PM10 GSM module have to connect to stations only.
GSM module works fine, only Voice Reports and SMS Reports are enabled on purpose.
The diagnostic shows GOOD GSSI and GSM/GPRS diag returns unit ok.
The SIM used is PAYG EE, system shows a T-Mobile 2G so it definitely picks up a network.
I tried adding numbers with and without area code, but cannot get it to send SMS or call private users when the Alarm triggers. I also sent SMS commands to the panel SIM number but did not receive them.
What am I missing?
Check your sim works ok in a phone first, what GSM module are you using?
Thanks, yes this was first prepared on a mobile so it has been tested.
The GSM module is GSM350_V2
It rings once and then I get a continuous tone (like a fax machine), it does seem to answer the call.
I am not in front of the panel at the moment.
On a side issue, I hit a 'SIM verify' diagnostic by mistake, but of course there is no setup for a server to respond. It is now stuck with the 'SIM not verified' TRBL code. How do I get rid of the message?
All good, it was down to poor SIM network signal.
Thanks for the help lums!:)
