Powermax 155x
11 Jan 2008
Bristol
Any help or ideas would be appriciated... I realise this is a DIY forum but I'm trying to work out whats going on with a powermax 155x (thermal store) on a sealed system. When the hot taps or shower is run the sealed system pressure drops down to 0bar within 5 mins. The mains pressure is good and have tried changing the calorifier already. Any ideas?
Sorry, should have said...I am corgi registered and know what to look out for on the powermax, unfortunately I seem to have come across a lot of them recently, but never seen this before.
then you had best email the admin and tell em your details so you can ask this question in the RGI only forum
Never realised you could do that, I'll get my deatails sent, I realise given the issues with this boiler its probably not sensible to give advice on potential problems incase some tries to DIY it. Cheers.
Charge in the expansion was 0.7bar but the pressure on the system drops with the hot tap running and the boiler isolated ( at a slightly slower rate.) The PRV was changed a month ago and the tundish was dry.
Charge in the expansion was 0.7bar but the pressure o the system drops with the hot tap running and the boiler isolated aswell ( at a slightly slower rate.)
that is a wierd one, but am sure that chrisr baxipot agile (as long as it isnt a kingfisher ;)) or poxi will sort it for you in the combustion chamber
what about with the filling loop disconnected and capped?...there's not really too many ways the heating water can pass back to the mains.
How can a leaking Plated heat exchanger cos loss of pressure in a central heating system
Unless the mains supply is unbelievably piiss poor that aint going to happen
Also are you going to apologies for that terrible slur you laid at me on a previous post onetap?
It was changed in the first post anyway. It's a wierd one but can only really be that the pressure reduction in the pipes when the tap is running is letting the ch water back into the dhw until the pressure equalizes...as far as i can see it from here.
To be honest I never tried it with it removed, I really should have. I just thought as the mains pressure was decent, the pressure would rise unless there is a fault on the non-return valve. I also tried topping the system pressure up, isolating the mains to the plate heat exch then running the taps but after the intial dribble, the flow stopped.
Thats along the lines of what I was thinking, it just didn't seem to reach a point where the pressures balanced.
