poxy punto
16 Oct 2006
Lancashire
Hi, not been down here for a while,bought next daughters car, 17, not passing for the next few months.
Got a punto for her, early shape, very clean, 112000mls, it's missing, do these cars have a problem with the coil pack.
Was okay till she, the seller, drove back from the mot bay. :eek:
check for loose wires and see if there are any vaccuum pipes hanging off.
Some mot shops will pull off a vaccuum pipe to get it through the emissions
We have a Mk1 punto with 100k+ on the clock and it runs a treat. It is very well looked after though.
Spend a few quid and give it a decent home service. Change plugs and leads, oil and filter, air filter. Take off breater pipes and clean them out if they are blocked or have mayonnaise in them. Check all vacuum pipes are in good condition and have no leaks. Take air box cover off the injection body and check the seal isn't borked and actually does seal the airbox to the injector body. Check the foil tube that draws hot air from the exhaust manifold in the winter is in good condition and not split.
Also, check to see if the modifications have been done on the radius arms to stop them failing the MOT on knackered bearings every two years. About £15 to get the modification parts (two rubber cups, one for each side) from FIAT garage and fifteen minutes to put on yourself.
Do all of the above and you should get a few more years out of the motor (change oil and filter regularly). I've worked on loads of cars, and the punto is one of the easiest to work on and one of the cheapest for parts.
