pre 70,s installation
8 Dec 2009
Ayrshire
Hi All
Where could i find information on 1960 ish supply, wiring and and installation methods for domestic and light commercial (hotels etc)
I would like to be able to recognise and establish the supply,earthing and protection characteristics of some older properties before they are upgraded I intend to photgraph these and some info in text form would be there for posterity per haps if someone thought they could help I can post some pics
Mac
If you look at the Part P Approved Document at http://www.planningportal.gov.uk/en...bcelectricalsafetypartp/bcapproveddocuments12
You will find an overview of older wiring practises somewhere around page 35.
Other than that you would need to get old copies of the Wiring Regulations the 13th and 14th would cover that period. :-
1955 13th Edition of the IEE Wiring Regulations launched, Reprinted, 1958, 1961, 1962 and 1964
1966 14th Edition of the IEE Wiring Regulations published Reprinted, 1968, 1969, 1970 (in metric units), 1972, 1973, 1974 and 1976
Those will tell you how things SHOULD have been done.
Cheers for that
Imay post some pics of one of the properties as it has one service fuse for each of the phases and one for the neutral I cant make out the size but it has been suggested they may be as high as 500Amps each ?
any comment
Mac
Ooh please post! We like pictures.
You need to get the DNO to sort out the neutral fuse. Its not allowed any more! (Do make sure its not just a solid link).
I assume the seal fairy has visited the premises in the past :wink:
Cheers TTC
Photos I will try to get I have posted for info on a digi camera for this and other uses
Mac
If the supply fuses are as big as that, normally they will be enclosed in a large steel box, as the supply will need to be fitted with CTs to meter the useage.
