Premier Elite 64 system move
19 Jun 2019
Have moved houses, taken the Elite 64 with me and am now ready to start the system up.
Have flashed to the latest firmware.
My questions are.
1. After flashing the firmware and removing all power will the setup from my old house still be stored, setup in new place will be the same.
2. Got all new batteries (all ricochet).Should I put the batteries in all the devices then power up the panel or power up the panel and then put the batteries in the peripherals.
3. When installing the sounders where in the Eng menu is the command to turn off the sounder.
Many Thanks
Dave
If you flash your panel you should default it.
The problem here is what versions did you flash from and to?
eng utilis, bell test press omit.
I flashed from 5.00.02 to 5.04.01
I was hoping that the previous programming would remain, have it on wintex so no great issue if its doesn't. Assuming the data remains Im not sure what the best way to power it all up, and was hoping not to have to learn all the peripherals.
Not a big system, 7 pirs, door contact, keypad and sounder, all wireless.
Dave
