    Dismiss Notice
Preparing copper prior to solder
Discussion in 'Plumbing and Central Heating' started by chriselevate, 14 Jun 2018.
  1. chriselevate
    chriselevate
    27 Jun 2009
    1,008
    Thanks Received:
    5
    Nottinghamshire
    Country:
    Just a bit worried that I've seen the plumber (who's fitting my new bathroom) not using a abrasive strips on the copper or a deburrer on the inside of the fittings prior to soldering. Just asked him why and he said that as they are new they don't need it and his flux does the job.
    Any thoughts on this please?
  2. Dan Robinson
    Dan Robinson
    1 Jul 2007
    55,556
    Thanks Received:
    9,330
    Hertfordshire & London
    Country:
    If it's clean then is fine. Deburring is nice but not essential if cut with a pipe slice.
    • Thanks Thanks x 1
  3. chriselevate
    chriselevate
    27 Jun 2009
    1,008
    Thanks Received:
    5
    Nottinghamshire
    Country:
    Ahhh phew! So shiny new copper that hasn't oxidised etc will be fine just to flux and solder?
    Thanks for that :)
  4. Crofton Gas
    Crofton Gas
    17 Jun 2017
    118
    Thanks Received:
    31
    Country:
    Flux has a cleaner in which is activated by heat, so oxidised pipe is fine, as long as it's not old or dirty. Most plumbers will use a pipeslice which leaves minimal burrs anyway
    • Thanks Thanks x 1
  5. CWHEATING
    CWHEATING
    6 Mar 2018
    169
    Thanks Received:
    18
    Country:
    Paranoid much?
  6. chriselevate
    chriselevate
    27 Jun 2009
    1,008
    Thanks Received:
    5
    Nottinghamshire
    Country:
    Yeah paranoid a lot. Don't want any problems with it and I've always thought that prepping the pipes in this way was necessary with all pipes. Glad it's not :)
  7. ReganAndCarter
    ReganAndCarter
    13 Sep 2010
    1,179
    Thanks Received:
    142
    Devon
    Country:
    That was the case years ago. Older fluxes were grease based and a lot milder. They didn't really clean the pipe, just stopped it oxidising while you heated it with torch. Modern fluxes are a lot more aggressive - either straight out of the tub or when heated with the flame. They're cleaning the pipe as well as preventing oxidisation.
    The thing with these modern fluxes is its more important to clean them off the joints after soldering and flush through pipes. Otherwise they can eat away at the copper causing pinholes. Apologies if this has given you something else to worry about.
  8. chriselevate
    chriselevate
    27 Jun 2009
    1,008
    Thanks Received:
    5
    Nottinghamshire
    Country:
    That’s great thanks. I’ve seen him apply a little flux after a solder and the use a wet wrag to wipe it off so that’s cool.
    Thanks for the input. Just glad it’s all good so far.
Loading...
Share This Page
