    Dismiss Notice
PRESSURE PROBLEM WITH FERROLI OPTIMAX HE PLUS 38C BOILER.
Discussion in 'Plumbing and Central Heating' started by ANTHONYMARCH1726, 30 Jan 2014.
  1. ANTHONYMARCH1726
    ANTHONYMARCH1726
    30 Jan 2014
    Thanks Received:
    Country:
    1 CAN SET THE SYSTEM PRESSURE TO 1-BAR AND THEN REMOVE THE FILLING LOOP. EVERYTHING WOKS OK WITH BOTH THE HEATING AND DOMESTIC HOT WATER. OVER THE NEXT 4 TO 6 HOURS THE SYSTEM PRESSURE WILL RISE TO ABOUT 3-BAR. I WILL THEN RELEASE WATER FROM THE SYSTEM UNTILL IT IS BACK TO 1-BAR AND THE PROCESS STARTS OVER AGAIN. WHEN IT REACHES 3-BAR I WILL RELEASE SOME WATER AND SO ON. IF I ISOLATE THE COLD WATER FEED TO THE BOILER THEN OBVIOUSLY THE PRESSURE REMAINS CONSTANT. COULD IT BE A PROBLEM WITH THE DOMESTIC HOT WATER HEAT EXCHANGE UNIT ?. I WOULD BE VERY GRATEFULL IF ANYONE COULD HELP ME OUT WITH THIS PROBLEM. MANY THANKS ANTHONY MARCH.
  2. Terry7556
    Terry7556
    25 Mar 2008
    2,861
    Thanks Received:
    559
    Staffordshire
    Country:
    antony march up to the middle sticky at the top of the listings page
    its about boilers and central heating
    click on it and look through untill you find the bit about recharging your expansion vessel
  3. Sponsored Links
  4. booty40uk
    booty40uk
    16 Feb 2012
    243
    Thanks Received:
    63
    Mid Glamorgan
    Country:
    Is your filling loop letting by?
  5. Gas2Air
    Gas2Air
    2 Aug 2004
    1,553
    Thanks Received:
    163
    Country:
    He's just said it's disconnected. Mains passing through hex.
  6. Sponsored Links
  7. booty40uk
    booty40uk
    16 Feb 2012
    243
    Thanks Received:
    63
    Mid Glamorgan
    Country:
    Doh!! :oops:
    MUST BE THOSE BIG LETTERS
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
