Pressure reducing valve when no water used
16 Jul 2009
Hull
Is a pressure reducing valve shut when there is no demand. I.e. the diaphragm is closed on the seat of the valve to stop water getting passed the valve/increasing pressure in the system?
It should be - the difference is between the design of a drop tight valve as against a standard Pressure Reducing Valve (PRV).
As well as when water is moving, when the water isn't moving then a drop tight valve should lock shut and stop any creep by the way the spring and diaphragm is designed. A non drop tight valve isn't designed the same way and then the higher pressure upstream can lift the valve as it's trying to equalise to the low side. I guess if a PRV isn't drop tight then it really shouldn't be called a PRV
The drop tight has a soft "rubbery" seat. Caleffi give a very good description/picture of how PRVs work.0
That's and that will only lift (if set to 3 bar) when the pressure drops below 3 bar. If say open a tap
Yes, but the dowstream pressure o ly has to fall by a tiny amount, maybe 0.1bar for it to start lifting.
Have you installed a new one??
G
