Pressure test
19 Apr 2015
Texas
Any reason R134a could not be used to pressure test a R410a line set on a heat pump ? Instead of Nitrogen .
The R134a should be removed when you vacuum down the system ?
And , yes , I have an EPA card .
Wyr
This is a UK site, you'd be better off posting on an American one
Do you Brits use the same refrigerants we use in the USA ?
Yhis is for a mini split . Do you all use mini splits ?
Thanks , :-)
God bless
Wyr
Air conditioning isn't so wide spread here as it would be in Texas... and as such even less DIY Knowledge about it.
Nozzle
Used to do some nightshift supermarket installs and we let the working refrigerant do the testing. Risky but we usually got away with it.
A major leak and the vac won't pull anyrode. You check and double check everything. Then triple check it again.
Having a brazed joint fail was rare.
It's a time saver and over a short period a nitrogen test might not detect micro leaks.
You might as well do the same as your risking a refrigerant leak in both cases. Unless mixing is a problem.
With pre charged units the valve would sometimes leak on the out door unit contaminating the refrigerant with nitrogen.
Especially if over pressurised.
On mini splits the connections are flare fittings . I torque them to spec , after coating the threads and mating surfaces with Nylog Blue .
The outdoor unit comes pre-charged .
God bless
Wyr
