Hi all,
I'm going to be testing my newly installed (by me) heating pipework and rads on Sunday for which I've hired a Rothenberger pressure tester for the coming weekend. As a novice I'd appreciate a few tips if any of you have the time:
- the hire co tell me that I'll need to connect my own inlet hose (they say just a garden hose) to the tester. I plan to just buy a connector I can tighten onto a tap but how does it connect to the pump itself? Jubilee? Push fitting?
- the (very scant) instructions I've been emailed show the pressure hose connector going straight into a radiator but I want to connect it to the plastic piping at the start of my heating loop. Again I can't seem to find out what the connector on the pressure hose is. I need compression or push fit obviously, but I'm concerned it is fitted with a screw fitting. How can I adapt that if so?
- what psi should I test to? (let me know if you need more info on number of rads etc to answer that)
All help very gratefully received. I want to get this right first time!
Cheers,
Helen
Cheers,
Helen
