I clearly have a leak on my system as the boiler is losing pressure daily although not a massive amount. I've read somewhere that if water is coming out of the pipe that runs externally from the boiler then this could suggest an issue with the boiler's pressure valve. I've checked everywhere, can't find any leaks and I have knocking pipes. Could this be a pressure valve fault and how would I check?
