We had a pressurized system installed at our house by our builders plumber 2.5 years ago.
The pressure vessel (24l intervarem) beside the pump has recently started to droop but it is not leaking (yet!). No water from the Schrader valve so I think the droop is due to the tank being poorly supported.
I guess it should be supported with a wall bracket/straps.
Clearly I need someone do this work. However, (to avoid a bodged job) I want ensure the appropriate supports are used.
What would you guys use?
