Pressure washer, steam cleaner advice ?????
7 May 2012
Essex
Hi all, I'm looking to buy a pressure washer, preferably a steam one. I need it to clean block paving and general use, but seems that a hot washer may be out of my price range, so now looking at just a good pressure washer as obviously a lot cheaper.
Does anyone recommend this or would you only use a steam cleaner?
Also what bar, psi, diesel, petrol would be recommended?
Many thanks.
So much choice! You can go for a diesel heated, electric powered Karcher for the best results, but my recommendation would go for a Honda petrol powered washer, from 6hp upwards.
What you don't want is a petrol washer with an aluminium pump head - it must be brass or it will burst in time....many of the cheapo Chinese things use these.
Make sure your choice has a chemical injection facility, and I prefer the type with the four fixable nozzles, rather than a lance with a universal nozzle.
John :)
Is your recommendation for a honda petrol powered washer a hot or just cold? And you would say this is adequate enough for cleaning block paving, decking etc.
For paving, concrete and decking a cold washer is fine....you'll be amazed at how much more powerful the petrol washers are compared to the domestic electric ones! Petrol machines also don't need to be 'rested' like the electric ones do.
For vehicle cleaning, a hot wash is much better courtesy of the chemicals used (thats out of my price range, never mind the size of the bloody things!)
John :)
