I have a flat on the first floor of a large Victorian house. I have a single garage as part of a block of garages about 100 feet away from the house. None of the garages have power, but as I needed power, about 6 years ago I ran a cable from the garage under the ground, up the wall and into my bedroom though the house wall.
It's all properly insulated and protected. In the garage there is a 4 way gang plugged into that end of this cable. In the bedroom it was plugged into a normal double wall socket.
I used the power for all sorts of usual DIY jobs one would do in a garage and everything was fine for many years. It powered my dehumidifyer successfully too which went on and off on it's own accord depending on the level of dampness it needed to tackle. All good.
Then one day, fortunately when I was inside the flat, I smelled burning. It was coming from the double socket in the bedroom. Immediately I shut of the power to the socket ring main and then removed the socket cover. The insulation on both black neutral wires had melted and were very close to the twin red live cables which still had insulation on. It was fortunate that it wasn't worse.
I went to the garage and saw that the dehymidifyer had been the only thing that was on. I brought it into the flat and tried it at another plug. It failed to work. I took it to the supplier who confirmed that it had a faulty relay or something. So, even though it had a 13amp fuse at the garage end and my plug was fused at the bedroom end it still f**cked up and ruined my socket wiring.
The supplier replaced the dehumidifyer and I've been using it since - in the garage - via another socket in the bedroom. It has been fine.
Recently I finally got round to fixing the wiring on the offending socket which has been a right ball ache because it meant removing carpet, underlay and floorboards. In the end I made the job even worse by enlaring the hole in the wall and installing a deeper back box for a more attractive flush cover plate. I am now at the point where I'd like to re-use this refreshed socket for the garage power cable. But I'm worried, after all this work, that the same thing could potentially happen again.
So... I'm wondering if there's anything I can do about this to prevent this happening again. I don't know anything about this kind of thing but how about wiring some kind of surge protector into the actual dehumidifyer cable that is in the garage plugged into the 4 way gang? Something whereby if the dehumidifyer goes wrong again it will protect my wiring?
Thanks. Sorry it was so long and boring.
