I have just removed an inset gas fire with a view to opening up the fireplace to the builders opening … initially for aesthetic reasons (to have a more rustic look) and eventually to get a wood burning stove fitted.
The original builders opening is only about 50cm and unfortunately it looks like whoever fitted the gas fire widened this by about a quarter of a brick either side to about 60cm to accommodate this. There is a steel lintel at the top of the opening but this is now only supported by about 8cm of bearing either side. There is also a concrete lintel higher up but this is about the same width as the steel one so I’m not sure that this provides much extra support? (photos below)
My first question is does the lintel need replacing with a 90cm one to allow a 15cm bearing either side? If so how easy is this to do? Am I best to get a builder in?
Second, there is a metal flue in place from the gas fire (see photos) – I’m guessing this is not suitable for a wood burner but wanted to double check as I don’t know how to tell?
Thanks in advance
The opening - about 50cm at the bottom + 60cm at the top
Steel lintel
Concrete lintel
The flue:
Thanks in advance
Steel lintel
Concrete lintel
The flue:
